DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Mastbruch
Quick question.
Mastbruch
Morning Fellas.
Excuse my ignorance but something I was thinking last night.  I believe I am lacking in the basic fundamentals.
Lets suppose you wanted to put an outside light up, or security camera, or anything along those lines. How would that actually be achieved when finding a power source because the nearest link would be the light switch but without a neutral how would this be possible?
Cheers
Share this post
Link to post
Doc Hudson
1 minute ago, Mastbruch said:
Morning Fellas.
Cheers
The nearest source would not be the light switch if it has  no neutral. You need the nearest source with a permanent live supply, a neutral, an earth and a suitable route which to run your new cable. The nearest accessory very often will not satisfy all of the above.
Share this post
Link to post
Mastbruch
Thanks Doc would that be a junction box or ceiling rose? or any
Edited by Mastbruch
Share this post
Link to post
Andy™
often fit a fused spur next to a socket
Share this post
Link to post
Mastbruch
Thanks Andy
Share this post
Link to post
Doc Hudson
Basically you just need to evaluate the simplest and most cost effective solution. It is a question that could have half a dozen or more possible answers that all comply with BS7671. Whichever method you chose, you need to make sure all cables are suitable for the load they are going to carry, And they have appropriate overload and shock protection, And any joints are in suitable enclosures with either maintenance free or accessible connections dependant upon their location. It may be more cost effective to run a longer cable to an easily accessible point rather than trying to find an unknown inaccessible point that is very close but a pain in the rear to find. BS7671 is actually very flexible in many applications  and as the saying goes there is more than one way to skin a cat! Don't start thinking that wiring regs only allow one correct solution!.
Share this post
Link to post
Mastbruch
Cheers Doc
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
