Biasi Riva compact boiler - no hot water pressure !!
benjibon
Active member
Feb 19, 2018
30
Hi guys, I just bled the radiators in my rented house and now the biasi Riva compact boiler has lost HW pressure, I've done some online research and can see a few answers but I would rather check with a pro before getting my landlord involved, I've attached images of the setup, what do I need to do?
open filling loop valves. usually 2 of them. fill to 1.2 bar. close valves
if its suddenly dropped to 0 then there could be a leak. if its slowly dropped then there's probably a small leak
Which ones are they Andy? The yellow and blue taps?
bleeding rads will always drop pressure, you need to top up from mains water. Sometimes you may find it fails to reset pressure sensor, a sharp tap sorts that out!
The silver flex is the filling loop. Open the valve slowly and watch the pressure gauge. Fill to a little over 1 bar no more than 1.5bar. Close valve on filling loop.
The loop has a black twist lever on one end and you’ll need a screwdriver on the isolator valve on the other end. The slot should be horizontal along the length of the valve when open and across the valve for closed.
Thanks sharpend, should this be done with boiler turned off at mains?
