DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
steptoe
I obviously have no idea what search terms to use
All I am finding is RF stats,
I want a hardwired programmable room stat, I know they exist, I have one in my own house.
Anyone that knows what they are doing give me a link,?
many thanks.
Share this post
Link to post
rainydays
Drayton digistat +2
Share this post
Link to post
steptoe
11 hours ago, Sharpend said:
How easy was that,?
:shakehead
Share this post
Link to post
Sharpend
You’ve gotta love a Steptoe for complicating things!!
Share this post
Link to post
ProDave
Just check they retain their program when the battery goes flat.  I have 2 here that you can have for the cost of postage that need re programming every time you replace the batteries.
Share this post
Link to post
steptoe
I need a hardwired one Dave,
There is no batteries in mine, and there won't be batteries in the one I fit either, sort of makes it pointless.
Share this post
Link to post
Geoff1946
I've been very happy with my Heatmiser slimline programmable 'stat installed about five years ago. Three core +E  back to the boiler for my Worcester Bosch combi  (230v).
Easy to programme, no batteries involved and you don't need an I-phone to turn the heating on or off!.
Only disappointment was that although "slimline", that is at the expense of needing a deep wall box.
I think they are still available.
Share this post
Link to post
steptoe
OK
so, I'm no further forward
I obviously need to be more specifc
I am looking for  for a mains powered, no batteries required, hardwired programmable room stat that is powered by 230v and will switch 230v
looked at your suggestion @Geoff1946 , it says its 12v ,,,,?   https://www.heatmisershop.co.uk/heatmiser-slimline-n-v2-12v-programmable-thermostat/?sku=Slimline-N V2&gclid=EAIaIQobChMIxb-Fkbyw2gIVjrvtCh15RAHhEAQYAiABEgKvnvD_BwE
Share this post
Link to post
steptoe
6 minutes ago, Murdoch said:
I do hope you are taking the p1ss with that...?   ;)
Share this post
Link to post
Murdoch
Nope
Its hard wired
Runs on 230v
and programmable
isn't that what you asked for?
Share this post
Link to post
steptoe
2 minutes ago, Murdoch said:
Nope
Its hard wired
Runs on 230v
and programmable
its not programmable
and it needs batteries,,,,,,
Share this post
Link to post
steptoe
but, I have scoobed you, @Murdoch , as I found this  https://www.tlc-direct.co.uk/Products/HOAS1.html
if I dont get anything better, it would work
Edited by steptoe
Share this post
Link to post
Murdoch
oops - wrong link!
The timeguard one I was thinking about was this one:
http://www.timeguard.com/products/climate/programastat/trt035-7-day-programmable-room-thermostat-with-frost-protection
But needs batteries....
Back to the drawing board then......
Share this post
Link to post
Sharpend
What’s the problem with batteries? I thought that the batteries allow settings/program to remain in the event of power cut?
Share this post
Link to post
steptoe
ime they actually run off the batteries, or , at least the display does
Share this post
Link to post
Murdoch
Or this one?
http://tpone.danfoss.com/
Share this post
Link to post
steptoe
Share this post
Link to post
ProDave
Mine was hard wired not wireless. A lot of them are designed to work as just a switch to replace a conventional stat with no neutral so are battery powered and just have a relay contact. That would be okay if the thing retained it's program when the batteries go flat. And of course it does NOT tell you that in the instructions and you only find out just over a year later when the batteries die, conveniently a few days after the guarantee has expired so you can't even return it as "faulty"
And it was not as thought I bought some unknown make, these are Horstmann programmable stat's
Edited by ProDave
Share this post
Link to post
steptoe
I wouldnt class something that needed batteries as hardwired
and surely the lack of requiring a neutral should have flagged something up to you.?
Share this post
Link to post
Geoff1946
11 hours ago, steptoe said:
They do both, (or did a while back). Some modern boilers use 12volts but mine is definitely 230.
Sorry I can't quote the stat model number but it isn't on the front and I don't want to disturb it. Also I see that some say for "for underfloor system", and some say "remote sensor optional" so that may confuse the types even more.
I suggest phone or e-mail Heatmiser.
Share this post
Link to post
ProDave
I needed something that was self powered.
This was at our old house with UFH. Each room has it's own heating zone and it's own room thermostat. But we decided it was daft to heat the bedrooms all the time so thought a programmable thermostat would give individual control to each room.
The room stats DO have a neutral, BUT the stat's are only powered {via the UFH manifold controller)  when the heating programmer is on.  So a mains powered programmable stat would not be powered a lot of the time and would look silly sitting there with a blank display.
The battery powered ones looked like the solution as the display would remain active all the time, not just when the heating was on. If only they would store the program parameters in NV memory and remember them during a battery change, they would have been great.
Share this post
Link to post
steptoe
Thanks @Geoff1946
I think I've found 2 models that fit the bill,
Share this post
Link to post
Sidewinder
Steps,
Have a look at Cosy kit, doesn't need the phone, but can be used with it, works in parallel with conventional stat in case it fails, and retains conventional stat as last chance.
Some good pricing from one of our local wholesalers on it, I MEAN good!
https://www.geotogether.com/
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
