Dimming a 750w Bulb
Apr 13, 2018
5
Aye Aye :)  What a cracking forum :)  I stumbled upon this by accident, but I wish I found it years ago :)
OK I digress, This is out of my remit as Im all Pro sound with a little Electrical knowledge :)  But I found in an old Cupboard 2 750w Bulbs LES, These are big, so I thought about putting them in the Living room (Not On the Ceiling :)  ) but as a feature because the elements are long and large, but... I want to Dim them right down so they glow and not burn my retinas out :)  So it looks like Ill need a Variac to do this, but can you think of any other way?
Thanks for any help
Kindest
Glen
You don’t mention the voltage so I’ll assume 240V. One my best photographs is of a 300W GES lamp (please note it’s a lamp, not a bulb). To take the shot took a lot of messing about with the voltage so I used a Variac.
For a decorative lamp about 40W should be a reasonable light but it will be very red/orange.
Lamps resistance = 77Ω.
For 2 x 40W, 56V is required but this wouldn’t a standard off the shelf 100VA transformer. I’ll leave to you to look for something within your budget.
Thanks Guys :)   Sorry I should have said its 240v, I have 2 of these Bulbs so I can use them both if need be.
Ive had a hunt on ebay for a Variac and were looking at about £150, (Thump!) so I thought if they could be wired in Series and then pop a Dimmer in place?
The Dimmer Racks we use have a pre heat on them with a variable voltage but we cant get it up high enough to make the bulbs glow, They will glow but it needs to be pitch black so we need a tiny bit more voltage.
So you think that a Variac is the only answer?
Thanks for all your help so far :)
If you wire the lamps in series and just use a standard 400W dimmer switch you should be OK.
Wiring them in series will dim them quite a lot and then the dimmer could be used to get the intensity you want.
Hi There, Just to say thanks for all your advice, the winner is....Ardet R :)   I grabbed a cheap 400w Dimmer from toolstation, not confident that it would work, but I took it home, Popped both Bulbs in Series and tune it on and it works better than perfect ;)   I can pop up some pictures if you are really bored :)
Thanks once again :)
Cheers
Glen
Thanks for getting back to us Glen, yip get the pics might have to get Admin to give you pic permission as it is not automatic until you have 10 posts.
I am glad it works to your satisfaction, it is always nice to be able to keep it simple.
