Veritas Part Set "night time" only
Linas
Apr 15, 2018
Hi
We've just moved in a house with a Veritas alarm.
When part setting, it seems that the alarm is only set internally (possibly for night time?). So two issues: a. when entering the front door the internal alarm goes off and b. (Most importantly), the external (loud) alarm doesn't come on in case of an intruder.
We've got the engineering code and manual but can't figure it out.
Any help would be much appreciated.
internal sounder only on part is default, you can change it
front door should start an entry, if it doesnt its set to the wrong zone type
all is in the manual...
Assuming that when full set you open  the front door and the entry timer starts, then it is as Andy said, its programmed to do that in part set, and you need to change the programming.
Presumably the previous owner was single.
