Paxton unit wiring for alarm control unit
Forumflyer
Apr 20, 2018
2
Hi
i have a job where the customer would like a Paxton net 2 plus door entry system wired into a texecom control box. It has a function and wired outputs to activate and deactivate the alarm when the door is released.
I have hit a stumbling block on how to wire them together
any help much appreciated
you need 2 pairs between them.
output from net2 is programmed as alarm and is connected to a zone on the texe set to latch
output form the texe is set to area armed / disarmed and connected to the input of the net2 so it knows if alarm is set or not
have a look on the paxton site, iirx there is a guide on how to do it. failing that, phone their tech support
Thanks for this
so I will put a pair from a zone on texe to Paxton.
On the output I only have a sw+ where do I put the other part of the pair
thanks
