DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Mastbruch
Evening Fellas.
I have basically set up a little test rig at home and when I get to testing the polarity on the 2 way lighting circuit nothing is happening when I switch the switches for polarity, its staying on the 0.72 I originally got on testing between the earth and line.
I have checked the wiring in the ceiling rose and the 2 switches and all look spot on. So I am stuck on this.
Any ideas
Share this post
Link to post
Andy™
you dont have switches for polarity in a normal installation, so a diagram of what you have done would be helpful
Share this post
Link to post
Mastbruch
Hi Andy basically exactly the same as the fella in this video. Where he is testing continuity and at the same time flicking the switches for polarity.  His r1 +r2 was 0.12 and then 999 when he flicked the switches yet on mine my reading is staying the same.
Share this post
Link to post
Sidney
Sounds like your switched line isn't actually switched.
Share this post
Link to post
Mastbruch
I may sound a bit stupid here but what do you mean mate and can this be corrected.
Share this post
Link to post
Murdoch
Or the strappers are connected incorrectly
Edited by Murdoch
Share this post
Link to post
Mastbruch
Cheers for the reply.
Just checked again and they look correct,.
Share this post
Link to post
Murdoch
Have you connected the SL to the correct part of the light fitting?
Share this post
Link to post
Mastbruch
I will go and have a proper look again and will get back.
Share this post
Link to post
ProDave
You are not testing at the loop through connection are you?
Share this post
Link to post
Murdoch
Or if you are using a kewtech adapter, are you actually reading Rn + R2 which obviously won’t change when the switch is switched...
Share this post
Link to post
Mastbruch
I am using a Kewtech mate, I am putting one of the testing ends on the earth terminal in the ceiling rose and the other testing end on the switched live.
Loop through connection?
Edited by Mastbruch
Share this post
Link to post
Murdoch
Something isn’t connected correctly
Share this post
Link to post
Mastbruch
I am going to have a proper good luck tomorrow, its got to be wired up wrong as you suggest.
I think I have tested it all properly, put the line into the earth terminal on the CU, nulled the MFT, gone to low OHMS continuity, then crocadiled the earth on the rose while connecting the other lead to the SL.
Share this post
Link to post
Tony S
Ignore the intermediate switch.
Share this post
Link to post
Mastbruch
Thank You Tony will check out that Diagram to mine.
Share this post
Link to post
Ardet R
If you have loop in wiring as per Tony's diagram then when you are testing for polarity and the readings are coming out the same, test the same test but put one probe on the permanent line (the other on earth) and see if that remains at 999 no matter where the switch is.
If so then you have connected the permanent line to the lamp and the switch is just connecting the loop in to the loop in.
This is particularly easy to do if wiring in singles.
Share this post
Link to post
Mastbruch
Still not happening after following diagrams. I am getting 0.24 ohms between the Earth and SL then nothing whatsoever happens when I switch the 2 switches below. starting to get on my nerves now TBH.
I have defiantly done the wiring correct. Took the N CPC & L to the ceiling rose, copied the diagrams from the ceiling rose to both sockets. To test continuity I have placed the line in to the earth bar yet still nothing.
The tester seems to be taking forever to Null too
Would it be the tester do you think?
Share this post
Link to post
kerching
Are batteries ok
leads
how are you nulling it
have you got a check card or known resistor you can check against?....if not then get an old lamp of known wattage, do a few sums to calculate resistance and use that
Share this post
Link to post
Mastbruch
8 minutes ago, kerching said:
Are batteries ok
leads
It hasn't been calibrated as yet mate I have it booked in for Thursday. I am Nulling it with both crocodile jaws, It kept beeping twice then kept coming up with 5.00 for some reason then eventually it would Null.
Share this post
Link to post
Murdoch
Are you switching 1 switch, then retesting, or switching both and retesting?
Share this post
Link to post
Mastbruch
I am holding one crocodile clip on the Earth and the other on the line whilst flicking the switches.
Share this post
Link to post
Murdoch
Hum, if you test, then flick both switches, you go from connected to connected.
Try it again, but just flick 1 switch then test again
Edited by Murdoch
Share this post
Link to post
Mastbruch
Right here goes.. When I then tested again I got 0.20 ohms whilst pinning on to the Earth and SL I then switched the switches and nothing but it seem to work if I press the switch off and press the test button again I get 19.99 then when I press the switch again and press test it goes to 0.20 and again press the switch then press test back to 19.99.
On this video he doesnt press the test button again.
Edited by Mastbruch
Share this post
Link to post
Murdoch
What reading does the mft show if it not connected to anything?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
