Spot The Fault (s)
Nov 28, 2009
14,650
811
Found on an EICR.
I may have confused you, I changed it to a "spot the fault" but someone had replied already.
The "flex" is in fact 3 solid cores about 1.5mm one green'yellow, one black, and one blue. Definitely those colours not burnt.
No idea
I was fault finding a central heating system a few months ago - flex with 3 black cores .................. not numbered or marked in any way.
The mind boggles.
Faults were:
No earth sleeving.
This was the first spur, with 2 more spurs from that wired in the "flex"
Size and colour of the "flex"
I am left wondering where this odd coloured, solid cored flex came from and what would it normally have been used for? You see a lot of strange stuff up here, a lot of it I think falls off the back of an oil rig.
Theres a German cable ..I think ...with those colours in it .    Is the outer sheath really tough PVC ?
NYM-J. Very commonly used in the south of Ireland. Somewhat similar to Hi-Tuff except it's not UV tolerant.
though you can argue Black is now a phase colour so nothing wrong with using that in an installation?
You absolutely cannot argue that as it is clearly defined that the phase (other than in a polyphase circuit) must be brown.
So WHY is it made with G/Y, Blue and Black if there is nowhere you can use it?  Just where CAN you use it with those colours?
I remember being shown a piece of that ,  must be 28 yrs ago,  by the NICEIC  assessor back then ...   the greatly respected  Mr Ray Digger  ...know throughout the Midlands .
If I remember right he thought it could be used in light industrial , commercial  as it would surface clip neatly and was tough as old boots.
