DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
ProDave
Spot The Fault (s)
ProDave
Found on an EICR
I may have confused you, I changed it to a "spot the fault" but someone had replied already.
The "flex" is in fact 3 solid cores about 1.5mm one green'yellow, one black, and one blue. Definitely those colours not burnt.
Edited by ProDave
Share this post
Link to post
Murdoch
No idea
I was fault finding a central heating system a few months ago - flex with 3 black cores .................. not numbered or marked in any way.
The mind boggles.
Share this post
Link to post
Sharpend
Would it be a burnt Brown as your description sounds like nym cable?
Share this post
Link to post
Andy™
no earth sleeving
Share this post
Link to post
roys
Screws missing from the faceplate causing the faceplate  to come adrift😀
Share this post
Link to post
binky
1.5mm flex on 32A MCB?
Share this post
Link to post
ProDave
Faults were:
No earth sleeving.
This was the first spur, with 2 more spurs from that wired in the "flex"
Size and colour of the "flex"
I am left wondering where this odd coloured, solid cored flex came from and what would it normally have been used for? You see a lot of strange stuff up here, a lot of it I think falls off the back of an oil rig.
Share this post
Link to post
Andy™
10 minutes ago, ProDave said:
Faults were:
No earth sleeving.
yay. whats my prize?
Share this post
Link to post
ProDave
The coil of useless funny "flex"
Share this post
Link to post
Andy™
meh. you can keep, it, save yourself the postage
Share this post
Link to post
Evans Electric
Theres a German cable ..I think ...with those colours in it .    Is the outer sheath really tough PVC ?
Share this post
Link to post
Sharpend
Thats NYM cable.
https://www.conrad-electronic.co.uk/ce/en/product/1517102/?
Share this post
Link to post
binky
seen it somewhere before, but can't think where. What's it mean't to be used  for?
Share this post
Link to post
Sharpend
It is used in ‘German’ shops.
Share this post
Link to post
ProDave
2 hours ago, Sharpend said:
Yes that's it, and I was right on the size. The outer sheath is really tough, the inner sheath is really soft.
Still struggling to understand the colours, though you can argue Black is now a phase colour so nothing wrong with using that in an installation?
Share this post
Link to post
Risteard
NYM-J. Very commonly used in the south of Ireland. Somewhat similar to Hi-Tuff except it's not UV tolerant.
You absolutely cannot argue that as it is clearly defined that the phase (other than in a polyphase circuit) must be brown.
Share this post
Link to post
ProDave
So WHY is it made with G/Y, Blue and Black if there is nowhere you can use it?  Just where CAN you use it with those colours?
Share this post
Link to post
binky
nowhere in the UK it seems .
Share this post
Link to post
Sharpend
We are installing it in Lidl’s, although it is brown/blue not black/blue.
Share this post
Link to post
Evans Electric
I remember being shown a piece of that ,  must be 28 yrs ago,  by the NICEIC  assessor back then ...   the greatly respected  Mr Ray Digger  ...know throughout the Midlands .
If I remember right he thought it could be used in light industrial , commercial  as it would surface clip neatly and was tough as old boots.
Share this post
Link to post
Risteard
NYM-J does not comply with any British Standard. (It is a VDE cable.) It's not suitable for BS7671 installations.
That said any of the NYM-J I have used has been brown/blue/green & yellow in 3-core.
However, the colours you have mentioned (if indeed it is produced with those) could be used on a single phase final circuit in the south of Ireland (to ET101 Wiring Rules) fed from a three-phase DB if the circuit is on phase L2.
Edited by Risteard
Share this post
Link to post
Sharpend
You are correct Risteard, it is a German VDE cable and is therefore not compliant to BS7671, however so is sy etc yet it is still widely used over here, which realistically makes a mockery of the BS7671 regulations?
Share this post
Link to post
Sidewinder
Deviations.
Also, as it is to DIN standards, then it is difficult to argue that it can't be used.
DIN standards have a common iEC ancestry to BS & EN standards.
However, try using BS only cable there and they will simply not allow it.
Which "technically" they should.
Share this post
Link to post
Sharpend
Level playing field as normal then. !
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
