DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Evans Electric
Not that stuff again !!!
Evans Electric
Doing some odd jobs in posh flat ...one was install a wall heated in the bathroom .
Couldn't drill the tiles ...they were made of irradiated boron from the planet Krypton ,  only Superman can drill a hole with his xray vision .
As usual  never there when you want him  so my mate had to go out to Screwfix I think it was  ....£14  for  two diamond plated , No 8 masonary bits .
Had this before on a bathroom refit ....where the hell do they get those tiles from ...Another galaxy ???
Edited by Evans Electric
Share this post
Link to post
Sharpend
Ah so what you need in this situation is https://www.google.co.uk/search?
works quickly and efficiently.
Meant grinder! Oops
Edited by Sharpend
Share this post
Link to post
Evans Electric
That is what we bought ..the wax filled drill bit  ....only needed 3  No 8 fixing holes .
Share this post
Link to post
Sharpend
Did you buy the grinder version or drill version? We used the drill version and they struggled, got the grinder version with a guide jig and hey presto seconds to get a nice clean hole.
Share this post
Link to post
Evans Electric
We got the drill thing .   Needed to drill 3  X   No. 8  Rawlplug holes for a heater .
Those tiles must be a nightmare to cut & fit .
Share this post
Link to post
Sharpend
Cutting them is easy, drilling them then grinder is a must.
Share this post
Link to post
Andy™
porcelain needs something like this
https://www.screwfix.com/p/erbauer-diamond-tile-drill-bit-6-x-67mm/51908
not going to get through with much else
Share this post
Link to post
Sharpend
That’s what deke has got, I’m suggesting the grinder version, it takes all the time out of the job.
Share this post
Link to post
Murdoch
These are brilliant ...................
Share this post
Link to post
ProDave
I use those cheap as chips arrowhead tile drills from Screweys. Contrary to popular belief they drilled all the holes I needed in the porcelain tiles in our bathroom no bother, just took slightly longer than ceramic tiles.
Share this post
Link to post
Sharpend
To be honest Dave I find the arrow heads good, the secret with them is to slow the speed of drilling, they then carve out rather than burn out.
Share this post
Link to post
Onoff
+1. TS do them too. Think I've got up to 10mm.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
