DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Rahul Patel
 3Ø 100amp supply
Rahul Patel
Hi
I am planning to convert an old office building with 3Ø 100amp supply into 14 self contained student studios (approximately 20 sqm)
Each studio will only have 2 electric heaters, 2 lights, 10 double sockets. The hot water will be gas heated.
I'm hoping someone will be able to tell me if the current 3 phase, 100amp supply be enough to power 14 units?
Your help is much appreciated
Share this post
Link to post
kerching
You need to talk to the electrician doing the work as this work is almost certainly notifiable to Building Control
are you reselling the electric or is it in with the rent?
it will need a lot more than you have listed as I assume this is to be shared facilities i.e. Cooking/bathing?  If so it comes under HMO and will,also need
escape lighting
Approved Fire alarm system on circs and individual apartments
Part P
possibly Part M
possibly Part L
landlords supply
....and that's without looking at it
Share this post
Link to post
Sharpend
Self contained studios is a bedsit with separate bedroom therefore all units will have scope for own appliances, own bathing etc.
Once again little detail expecting big answer?
Edited by Sharpend
Share this post
Link to post
Murdoch
And communal areas and outdoor circuits need to be considered too ....
car chargers anyone?
Share this post
Link to post
Evans Electric
A job like that needs to be designed properly   , either by your contractor or A.N.Other  .
You don't just do that sort of job on the back of an envelope   with a couple  of electrician's mates  from darn the  battle cruiser
Share this post
Link to post
kerching
Secondary means of egress anyone?
Share this post
Link to post
Blue Duck
Where the dealers hang out?
Share this post
Link to post
kerching
Ah yes, around the back passage
Share this post
Link to post
Murdoch
Relying on "internet" advice could be an expensive mistake
My recommendation is to get a price from the DNO to upgrade the incoming supply - then you can build it into your costings .
But beware, it may take a few weeks for them to come out, then if you go ahead there will be a delay in in actually happening..
Hope this helps
Share this post
Link to post
Andy™
well to make sure its adequate you could use a logic relay and some large contactors.
put 5 studios per phase (communal areas takes the last space on L3)
set a contactor so that each studio receives power for 2 minutes every 10 minutes, alternating between studio's. there you go, 100a available per studio. fit as many heaters as you want.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
