One of those air-cooled, soft top CU's with with cover thats gone missing years ago...
SPECIAL LOCATION
Trailer Boy - Electrician.
Mar 28, 2008
14,269
922
Found this one yesterday....
No point saying spot the fault.. you'd run out of time & ink writing em all down!
P.S. I have removed no covers or touched any part of the installation...
this is exactly how it was .
domestic property...
That black cable disappearing off on the right hand side..
is the Rubber incoming supply feeding it all.
At least there is a rodent mesh😀 on the incomer
Nooooo...  the rodent mesh is on some of the final circuits going out.... :D
The incomer bends off to the right hand side above the round JB...
The other end appears here..
BUT they do have a nice insulated switch to manually cut off the power if needed!   :pmsl1:
I am guessing the switch was added by whoever fitted the meter?
I am waiting to see if Deke owns up to it being one of his early jobs.....
Its a 'B64' postcode area....
Which by my calculations is within range for deke to reach and still have more than half a tank of fuel left?    :C
I was asked to go there as the customer wanted a quote for a new consumer unit!!!!!!!!!!!!!
So I thought...  Well at least they got that bit right finally realising it was out of date!.    :(
SO....
do you reckon an RCD would stay on if added to any of those circuits?   :D
I did explain to them it would take a bit more than a typical single day CU swap-over..   :pmsl1:
Its some years since I worked in that area  Specs ,  Cradley &   'Ode  'ill  aye it  ?        An I aye sin a board loike that afore either ...it baint a Wylex by the looks on it ?
When I worked for Southalls in Stourbridge  we  did a lot of work at Cradley Foundry ......a right filthly  *++?<$£2!     But no domestic jobs , so it aye one 'o mine  m' mon. :innocent
