Optima G3 (help needed on door contact)
Luddite
Oct 2, 2018
13
Hi
Some years ago I put the complete system
Then some years after that I replaced bell box and the small spare panel.
I am now trying to practice dementia (lol) because my brain seems to struggle with what I now need to do despite having all the manuals.
My son had yet another motorbike stolen so I have built a metal shed and have wired a flush door sensor to it, now I can not get it recognised by the control panel.
On the existing system zone 3 & 4 are joined so I copied the wiring to the flush contact on 7.
which is black&red to silver screws, Yellow and blue together to brass screw.  Yellow & blue in box to tamper, red & black to zone 7.
I have now dug some of my old notes out and they show different.
Black & red to silver screws, then yellow, green & blue to brass.  (do all of these last 3 go to tamper?)
Please refresh my memory
thanks
PS  I can not remember whether I have to initialise to get the system to recognise thgis new zone.
What I did what set it to chime but nothing happens (no red light)
Don't worry about what colour you use  other than its best to follow the rest of the  system  .
The 2  silver screws  are the contacts  (  switch )   .  The brass  screws are just remote terminal  screws  .
So  your red & black  are in Zone 7  which is OK   .  (  Did you remove the link?)
The Yellow & Blue   (Tamper )   need to go in series with the other tamper  loops .
Ignore the other two colours in the cable.
Thanks mate
just got in from watching the blues game,
Love the sketch btw
toomorow (when sober, hic) I will be back asking questions after studying your plan (or getting you over to b31) lol
thank you, as mentioned above
Blue is unused  ,  yellow & green twisted together on a spare terminal   .   Really you should connect the tamper across the  tamper switch in your door contact  ...you'll see two metal contacts  that open when you remove the cover .
I'm not familiar with your panel  but if the zones are programmable  they usually default to  " Guard"  . So it should work .
Sorry mate, gonna act dumb now
Are you saying Yellow to 1, Green to 3 for example on door switch - with them both going to tamper in alarm box
The way I have it, (yellow & green together on 3) nothing is responding
EDIT:
Oh, just re read it.
open the switch, find which 2 are the switch and put yellow & green to those, Is that correct please?
Tell you what , Ned  ,  don't bother with the tamper wires  , ( They need to be in series with the  rest of them )           just connect  your red & Bk to the silver contacts  in the door switch  and the other ends into Zone 7  after removing the shorting link ,  Forget the other cores .  If it doesn't work you need the manual to reprogramme  zone 7   .
You could connect it into another zone which is already set to "Guard"    but must connect it in series not parallel  .
Honeywell supply those panels now ,  you can phone them  for an engineer's  manual.
