DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Barx
Fixing Portable Generator
Question
Barx
Can somebody just confirm that the rotor on a brushed portable genny should have continuity when tested at the slip rings? It's just a winding isn't it?
Head is a little fried and no power coming out this bloody thing. It's testing open circuit so thinking it's knackered.
With the avr disconnected, getting 18v on brushes which is apparently too high and also indicates knackered rotor.
Cheers
Share this post
Link to post
11 answers to this question
  • 0
Geoff1946
Assuming we are talking about one of the small (~2kVa) cheap and cheerful type, I think there may be a diode in the rotor winding as well.
Bit hazy now but I did fix one a couple of years ago and I had a generic circuit diagram. I'll see if I can find it later.
Share this post
Link to post
  • 0
Geoff1946
I've found my diagram, but sadly it isn't going to help you.
Mine was actually only a 600 - 700 watt job, but had no external connection to the rotor. i.e. no slip rings.
The rotor just comprised a winding short circuited with a diode.
As yours has slip rings then I would expect continuity. Presumably its fairly heavy wire and I would be looking carefully at the terminations if it's O/C.
Share this post
Link to post
  • 0
Barx
Hi @Geoff1946
Yeah, that's the type of unit I'm talking of. Thinks it's  2.5kW.
Got another one turning up soon (hopefully tomorrow) so will check that one out to answer my own question ;)
Thought it would be an easy one for people with brains (not me), but posted here and 2 x facebook groups. So far, your the only person that has replied, lol.
Share this post
Link to post
  • 0
Doc Hudson
3 hours ago, Barx said:
Hi @Geoff1946
Facebook!?  I didn't think we mentioned that here? It is rumoured you could be banned for a month for quoting any Facebook references. Lets hope no one else noticed! Do let us now what you find out as or when this 'other' generator arrives.
Share this post
Link to post
  • 0
Barx
Ok, new genny turned up today. Looks pretty much same except a few bits of metal are different shape etc. I whipped the cover off the alternator (after checking that it works fine first), removed connections to brushes and tested between the brushes (which are obviously connected to the slip rings. 60 Ohms!!!
Tried it both ways too to see if there are any diodes in place and got same reading both ways.
So, looks like the rotor is indeed kaput on the old one.
Share this post
Link to post
  • 0
binky
makes sense, any motor winding will have  a resistance albeit not very high.
Share this post
Link to post
  • 0
Barx
Thats what I originally thought @binky but it was O/C on the non-working unit and then I doubted myself. Not a master of motors or alternators. I started to question how a coil withing a coil generates electricity. Where the magnetic field comes from etc. As mentioned head was a little fried and had little info with me. Turns out my theory was correct, which is nice. I also now wish to learn / revise a bit about the whole subject.
Share this post
Link to post
  • 0
binky
know what you mean, I've forgotten so much basic physics and priciples of electricity / motors coils etc etc due to lack of use...
Share this post
Link to post
  • 0
Geoff1946
Here is the diagram I mentioned earlier. This was a very small (~600w) cheap & cheerful, I think from Aldi'
As you see there are no sliprings and no regulator. Somewhat surprisingly it worked OK once I "fixed" it.
It hadn't worked from new, and I dismantled tested and rebuilt it more times than I should admit. I even replaced the capacitor, as I couldn't test that.
Eventually, picking up on basic principles,  a penny finally dropped!
it relies on residual magnetism in the stator to initially energise the rotor. There clearly wasn't sufficient residual so nothing happened.
I connected the stator output winding to a car battery and counted ten. Put it all back together for the final time and it worked fine.
Generator.pdf
Share this post
Link to post
  • 0
Tony S
Generator.pdf
Ahh, that old trick, flashing the stator to reintroduce the residual magnetism. I’ve only ever done it a couple of times to get the exciters working on our MG sets.
Another way is to give it a good clout with a lump hammer, it jolts the magnetic flux back in to line.
Share this post
Link to post
  • 0
Geoff1946
I think if I hit that Aldi one with a lump hammer it would never work again! A tack hammer maybe.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
