DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
ProDave
You cannot cut the seal on a meter, so .......
ProDave
So the "electrician" that did this CU change (some time ago) just joined the substandard N tail out of the meter to his new tail, with an "interesting" joint method, and a reel of tape
Looks like he only had 1 Henley with him and he used that for the L connection.
Share this post
Link to post
Badger
That is down right dangerous and stupid
Share this post
Link to post
kerching
I've seen worse!
meter tails ....stripped back 2" and cable tied to new piece then wrapped in Sellotape
seemed to work as long as there was no load drawn
Share this post
Link to post
binky
I did a job a while ago, the whole house was wired in white cable, but the old board only had black VR in it. Having decided to investigate, (I needed to change the board anyway) I lifted the old bit of carpet I had been sat on many times to find the cables had been joined by twisting the conductors together, wrapping in masking tape, and with Iceland carrier bags around that - Iceland must do really good plastic bags!!!
Share this post
Link to post
Evans Electric
:innocentOh  Yeesssss !!  If they were Iceland  they'll be fine  ...none better for insulating dodgy cable joints.   :innocent
Edited by Evans Electric
Share this post
Link to post
Evans Electric
And still  the problem of no downstream isolation  in domestic premises  continues.
Now we even have untrained meter monkeys who are allowed to cut & re- seal  etc     but not a qualified electrician .
Example of today's  meter fitter's work  on a new bungalow I did last year .
Share this post
Link to post
ProDave
At least he tightened it enough to puncture the insulation.
No problem wit isolation on my job today, no seals on the DNO's fuse.  By the time I go back to correct this Amelie will have visited and there will be none on the meter either.
Share this post
Link to post
ProDave
I finished this job today.
Underneath all the tape, it was literally the strands of the small tail, wrapped around the big tail. And once the tape was gone there was not much holding it, they slid apart very easily.
Beats me how anyone could do that and think it acceptable. And also how it has not seemingly got hot and bothered before now.
Share this post
Link to post
binky
seen that many times, as long as it is clamped hard under the terminal screws it works fine.
Share this post
Link to post
ProDave
But that's the point, it was not clamped anywhere, just like that in free air, wrapped in half a reel of black tape.
Share this post
Link to post
binky
missed that bit, must have been very good tape :^O
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
