DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Dairyspark
External sounder beeping intermittently
Dairyspark
Hi everyone, could anyone point me in the direction of reasons why the external sounder would beep every 10-15 minutes?
Customer has changed battery inside control panel which has topped the internal beeping but external is still beeping away
Share this post
Link to post
Andy™
new batteries required in the bellbox? what system is it?
Share this post
Link to post
Dairyspark
Its a Mossie and Kirkland alarm system, if that's not what you mean then I'm not sure as i have Zero experience with alarms, my company doesn't even do alarms, its a my bosses family and I've been sent to fix it 😭
Share this post
Link to post
Andy™
no idea. thats more like the instler name not the manufacturer
Share this post
Link to post
Richard-the-ninth
Mossie and Kirkland IS the name of the company who installed the alarm (They were bought out in 2012) we need to know what make / model the panel is, but to be honest, I have (in all my years) never heard of an external sounder beeping every xx minutes because of a low battery, usually the battery just fails.
I have found "hidden / lost / forgotten" smoke alarms in the vicinity with low battery making a beeping noise, so I would check the sounder to be 100% sure it is the cause of the noise, and if it is, change it to another external sounder as it will solve the problem and is quicker in the long run.
Share this post
Link to post
Dairyspark
It’s a ADE optima Compact, if that helps any and it’s 100% beeping from the sounder
Share this post
Link to post
Richard-the-ninth
As I said, change the sounder. 99.9% of external sounders will work on any panel.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
