DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
kraig1
shaver socket
kraig1
Hi, what size cable should I use for a shaver socket?
Share this post
Link to post
Evans Electric
Hi  Kraig  are you a DIYer ?
Share this post
Link to post
Andy™
the cable size thats determined in your circuit design using tables etc in BS7671
Share this post
Link to post
kraig1
I'm a bit more advanced than a DIYer but not a professional, I took the power shower out and having a shower above the bath, I wanted to use the 1 mm cable from the power shower if possible?
Share this post
Link to post
Andy™
you could reuse it, but you cant have a shaver above the bath / shower in zone 1
and since youre modifyin circuits then youll need to make sure all circuits in the bathroom are RCD protected along with various other stuff that youll probably ignore...
Share this post
Link to post
Evans Electric
All wiring in bathroom needs to be via an RCD  , which you may have in the board .  Have you got a proper isolating transformer socket ?
Share this post
Link to post
kraig1
The cable that was for a separate shower now removed is already on an rcd, It will not be above a bath I never said it would. It is over a metre away from the edge of the bath (I have a big bathroom) Thankyou all for your input.
Share this post
Link to post
Andy™
most showers are located within the shower  / bath, not a metre away. so you could have been planning to reuse the cable where it was.... some people would. you also need to consider safe zones if you are relocating the cable too
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
