GeddyMortgage
Active member
- Oct 15, 2018
- 36
- 1
Recently had some 'NICE' automated gates installed, using the Toona 3 system. Really happy with the install, very tidy, generally happy with the work. Though one niggle i've got is that my drive is at a bit of an odd angle. Which means, to get through the gates easily, both leaves have to open as wide as possible.
During installation, the installer was able to make one of the gate leaves go wider during calibration than what it can in operation. I can't remember his exact explanation for that, but i'm not technical, so accepted it. Since then though, we've found it is a little bit awkward getting through the gates for some of my family. So i've tried to do a little research toward whether there's an easy way to get these gates opening "more"...i've been looking at geometry, and i'm little confused.
I've been looking at this guide https://www.easygates.co.uk/to4024-geom.asp and comparing the measurements to my gate, mine are are (A)155mm and (B)155mm
I guess my question to you all, is, are any of you of good understanding of Geometry. In the guide above, is it basically saying the measurements within the dark green zones would allow the gates to open further...?
Parma
Parma
