DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
cjonesguitar
Lighting in garage
Question
cjonesguitar
Hi, I have a garage. I think it is about 2.5m by 5.5m. Any recommendation for lighting? I have thought about one larger fluorescent, which spreads light across the center? Even a double fitting?
Two smaller ones is an option. Also remembering in mind it will get v. cold.
Share this post
Link to post
  • 0
Geoff1946
Depends entirely on what you want to do in there. If you just want to put a car in safely, you need minimal light. If you want to use it as a workshop you need a lot more.
Whichever, these days I wouldn't install fluorescent, (which are slow to come up to full output in extreme cold),  but LED.
Condensation may be an issue too, so IP44 may be wise.  - I'm not sure if its mandatory for current regs, other members are more up to date than me on that.
Share this post
Link to post
  • 0
Evans Electric
As Geoff says , what will you use it for ?
1)   Parking the car  ...a 5 ft  LED  48W   Batten fitting  would be fine .     Even a  24 W  .
Share this post
Link to post
  • 0
cjonesguitar
I actually want it to be flexible, so what use is chosen in the future, as I may let it out....
Share this post
Link to post
  • 0
Evans Electric
Put two fittings in then and worry about it later .
What about sockets if you're letting it out for unknown  purposes.
Share this post
Link to post
  • 0
cjonesguitar
Two 5 ft LED 48W?
I am going to put one double socket near the consumer unit. Do sockets have an IP rating?
Share this post
Link to post
  • 0
binky
in theory you don't need IP anything in a garage becuase it is dry! In reality condensation in light fittings can be an issue along with spiders, so it's worth putting IP rated lights in to avoid nuisance tripping of lights. I would suggest 2off 5 ft LEDs to give a good spread of light.
you can get IP rated sockets, but I generally put 'metal clad' in garages becuase they are 'bash-proof' - just make sure any cable entries are sealed up to prevent spider entry.
Share this post
Link to post
  • 0
cjonesguitar
To be honest, I don't think they be bashed... being sealed is important. Also the Garage is breathable...
Two 48w LEDS binky?
Share this post
Link to post
  • 0
Murdoch
Two 48w LEDS binky?
Why do you think you need sealed sockets?
Share this post
Link to post
  • 0
cjonesguitar
Cobwebs etc... no water tight.
Share this post
Link to post
  • 0
binky
Two 48w LEDS binky?
 Fair enough, use plastic or PVC back box, just don't leave large cable entries to keep insects out. My prefernce is PVC back box with a TRS gland - the PVC boxes are designed for use with conduit, so have 20mm cicular knockout for the TRS gland (you could just fill any gap with silicone).  Small spiders and woodlice are very god at living in the back of sockets and can occsionally trip electrics out.
2 - gives better spread of light if arranged equally spaced along centre of garage if you are thinking of renting out as a potential workshop.
Edited by binky
Share this post
Link to post
  • 0
cjonesguitar
I'll need to look, thanks Binky. Just out of interest, the other thing I am doing is having two doors at the front that open outwards. This give an option to leave one permanently closed, with more storage space behind that door.
Share this post
Link to post
  • 0
binky
so 2  lights equi-spaced should give good illumination without overkillig it.
Share this post
Link to post
  • 0
Bruspark
Try to place one or more lights so that you can see into the car boot or bonnet if one is parked there.  Even if no car there lighting from two angles is always better
Share this post
Link to post
  • 0
Evans Electric
As Bruspark says ,  if  you're parking a car in there  you set the lights out accordingly .  As in ,  don't put the lights over  the car , all that does is light up the car roof.
I'm not familiar with the term  "  A breathable garage"  TBH
On 15/01/2019 at 08:47, binky said:
Small spiders and woodlice are very good at living in the back of sockets and can occsionally trip electrics out.
A good point !   The 19th edition will be looking at the rights of spiders , woodlice  & small insects in general  to the right of access to electrical accessory boxes ;)  All this sealing up is forcing insects to seek alternative accommodation .
Or a corrigendum may be issued  to the 18th ....this will result in a new qualification ....details of courses  available soon.
It will take it's lead from the automotive industry ,  who now recognize the rights of spiders to set up residence  behind vehicle wing mirrors and a right to  be able to build webs in it's immediate area.      This will be termed Zone 1 .  The area behind the mirror will be Zone 0 .
Edited by Evans Electric
Share this post
Link to post
  • 0
binky
spiders in wing mrrors - they love them :^O
I had to transport a load of old light fittings to the scrappy from a car park job a few years ago. Took about 6 months to clear the spiders out of my van - annoying little sods, every morning a new web in the corner of the windscreen / bulkhead / air-vents...
Share this post
Link to post
  • 0
Evans Electric
There one in the mirror of wife's car, called Brian , been there for at least 2 years .
Share this post
Link to post
  • 0
phil d
I had one living in a mirror on one of my cars, it used to pop out and have a look around when the car stopped at the end of a journey, one day we'd driven to Blackpool after having a look around it got off the mirror and disappeared, obviously it fancied a holiday. I can't help wondering if it stayed in Blackpool or whether it hitched a ride to somewhere else.
Share this post
Link to post
  • 0
Geoff1946
It's fit and well and living in the mirror of my xtrail. It regularly weaves the toughest of webs stretching back to the door. They easily stand a 100mile or so drive intact.
Share this post
Link to post
  • 0
phil d
You never know, maybe its my spider living in your mirror, lol, that enjoyed spinning webs, I think it left when I joked about charging it rent. lol
Share this post
Link to post
  • 0
Tony S
Pink Minx hates spiders but she got quite used to Boris on my bedroom wall. He never came down to the level of the bed.
Share this post
Link to post
  • 0
cjonesguitar
Hi, I have viewed the inside of the garage. I really believe florescent tubes would be more suitable. The lights need to go sideways on the innerside of the joists. I think LED are just too fancy for temp lighting.
Share this post
Link to post
  • 0
binky
I have lights fitted like that in my garage due to low roof height, it creates a lot of shadows. You would be better off with more small lights in those circumstances, or perhaps even LED strip along bootm edge of joists
Share this post
Link to post
  • 0
cjonesguitar
I suppose the other option, is just two battern bulb holders.... or just have them both on the centre joists one on each side... or two small tube inbetween the joists (which means fixing some new smaller timber...
Share this post
Link to post
  • 0
cjonesguitar
The other simple option would be have one bulb on a joist near the back, the diagonal battern type. And just leave it for whoever buys it next. It is a standalone garage, and not with any house. If it has power they sell easier. This is the only reason I am connecting it. One bulb would light it, as it is only similar to one room?
Share this post
Link to post
  • 0
binky
it would work, but depends what you want to do in there.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
