DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Rutts35
How many cables can you fit in a JB
Rutts35
This DIY'er says he can get nine cables in....... easy. 🙄
Share this post
Link to post
ProDave
I have seen a lot worse. Shame he had no earth sleeving,
Share this post
Link to post
kerching
Why use connector strip when there is a spare terminal ?
I too have seen more than that in one JB.!
....and twisting the earths! WHY?
a twister is not a tester
just saying
Share this post
Link to post
Tony S
Why didn’t they use the centre left terminal? It would have made it so much neater.
Share this post
Link to post
Rutts35
Yeah it would have made all the difference. :slap
It was conveniently place away from any ceiling roses or switch drops so took a while to find!!
DIYer's. Same house theres spurs on spurs. Usual stuff. There's no CPC in the lights anyway only what the guy added. The conusmer unit had been replaced a while ago. Contactum board. Not an RCD in site and it's TT so I'm guessing that the DIY'er who did the above put that in as well.
Edited by Rutts35
Share this post
Link to post
Andy™
could have at least connected all the conductors inside (except earths), fitted the lid then twisted all the earths together over the top of the lid
Share this post
Link to post
ProDave
Ah yes, the twisted earths over the top of the lid making it impossible to access (without untwisting)
And the "hunt the JB" game when you find a house wired spider fashion.  You know there is a big JB on each floor but where?  The one for downstairs is under a floorboard, probably now covered in laminate flooring but nobody knows where.  The upstairs one is under 6 layers of loft insulation.  Somewhere.
Share this post
Link to post
Rutts35
Hunt the JB or as I told the house owner the ****tiest treasure you can take part in!!
Share this post
Link to post
kerching
Or if you could find any you could use those Ashley JB brackets that sat under the JB and gave you two earth terminals .
i thought they were a really neat idea until, it was decreed that all joints should be in an enclosure
Share this post
Link to post
Tony S
I liked the Ashley boxes for the few domestic installs I did. My first house must have been held together with them. Not out of choice, Mrs. S could change her mind with the months or the seasons. It got to the stage that for the first floor lighting I used the Octopus wiring method, so flexible. One central JB from which all the lighting wiring radiated. I know @Sidewinder has considered this method for his house.
Share this post
Link to post
Blue Duck
Think it was @steptoe .
TBH, probably the best way to do it.
Share this post
Link to post
Rutts35
I used to use the Ashley 501's  all the time before wagos were about. Was considering a central jb for my own gaff
Share this post
Link to post
Tony S
Octopus is so flexible but a system few understand. I used Weidmuller DIN rail connectors in a 8” x 8” adaptable box.
Share this post
Link to post
Tony S
Do it, makes life so easier afterwards.
Share this post
Link to post
Rutts35
I was gonna use some sort of din rail system. My loft is full of poxy jbs (previous owner was a builder). They're everywhere!
Edited by Rutts35
Share this post
Link to post
Blue Duck
Am using wago top jobs to build lighting control panels, they are pretty good once you get over how tight the springs are.
Share this post
Link to post
Tony S
3 minutes ago, Rutts35 said:
I was gonna use some sort of din rail system. My lift is full of poxy jbs (previous owner was a builder). They're everywhere!
One tip, glue an encapsulated drawing to the lid of the box. Umpteen cables going here, there and everywhere is a mind blower!
Share this post
Link to post
roys
I am about to rewire my own house just now, I am just in the middle of making up two junction boxes with Wago top loaders on DIN rail for the upstairs and downstairs lights. If I get a chance I will post a pic of the box unpopulated but with terminals tomorrow.
Has to be the best way to wire lights, pity it has fallen out of fashion.
One of the boxes will be mounted on a wooden board in the loft the other on the 1st landing in the cupboard where the hot water cylinder used to be.
Share this post
Link to post
Tony S
I look forward to seeing old ways in a modern environment :Salute
Share this post
Link to post
roys
Box one of two under construction for upstairs and downstairs lighting circuits.
4 way top loader Wago terminals with disconnector used.
Using a spare terminal as a separator between live, earth, neutral and switch live. (I know I talk old money, but I'm retired 😁)
Edited by roys
Tidy up
Share this post
Link to post
Rutts35
Can you not get jumpers to link the terminals?
Share this post
Link to post
Tony S
That is why I would recommend Weidmuller terminals. Busbar sections make them so easy and therefore neat.
The original “Octopus” system.
Share this post
Link to post
Rutts35
Wagos do do jumpers for some of their terminals. Although weudmuller with the jumper bars are good to use.
An original octopus. Take from a rewire?
Share this post
Link to post
roys
You don’t get jumpers for the Wago terminals that I have used, although other Wago terminals do have the jumper facility.
I like these terminals because they are 4 gang (although some of that is lost through the addition of wire links) and they have the disconnector lever on them so I can easily isolate parts of the circuit if need be.
Share this post
Link to post
steptoe
I did , but the post is well buried by now
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
