DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Social Integrator
Voltimum - Free T6 Tester and software with Fluke 1660 Series
Social Integrator
Until 30th June 2019 and while stocks last, Fluke UK is offering two 1660 Series Multifunction Installation Testers with a free innovative T6 Electrical Tester plus data management software.
The Fluke 1664 UK-T6 comprises a 1664 FC Multifunction Installation Tester with a Fluke T6-1000 Electrical Tester plus free Fluke DMS Data Management Software; the Fluke 1663 UK-T6 comprises a 1663 Multifunction Installation Tester with a free Fluke T6-600 Electrical Tester plus Fluke DMS Data Management Software.
Fluke T6 Electrical Testers with FieldSense Technology make troubleshooting safer and more efficient by allowing electricians to take simultaneous voltage and current measurements, not just detection, without test leads. These offers and other Fluke Specials may be found at www.fluke.co.uk/promotions
The Fluke 1664 is the only installation tester on the market that helps prevent damage to appliances that may be inadvertently connected to the system under test, and it also makes it easy to share test results over a smartphone using Fluke Connect.
The 1664 FC features an Auto Test function that does 5 required installation tests in one sequence, ensuring compliance with BS7671 17th Edition Wiring Regulations. Fluke DMS Data Management Software uses the captured results from the Fluke 1663 or 1664 for data recording, offers easy-to-use administration and reporting and provides printing of test reports.
Troubleshooting electrical systems can be time-consuming and potentially dangerous because it requires access to metallic contact points.
Fluke T6 Electrical Testers make it possible to take reliable true-rms measurements in crowded junction boxes or along conductors with inaccessible end points, saving time, minimising potential errors, and greatly reducing the possibility of arc flash. The rugged testers are 1000V CAT III, 600V CAT IV safety rated for the T6-1000 (600V CAT III for the T6-600 model) and feature an easy to read display with a backlight.
With the Fluke T6-600 and T6-1000 testers, electricians can:
  • Be safer: Measure voltage up to 1000V (T6-1000), or 600V (T6-600), through the open fork without test leads or exposed conductors.
  • Be faster: With no need to open panels or remove wire nuts, electricians can speed through troubleshooting.
  • Be more efficient: Simultaneously measure and display voltage and current on the T6-1000 – toggle between readings with the T6-600. The T6-1000 measures resistance up to 100 kOhm, (the T6-600 to 1kOhm), and the T6-1000 also measures frequency.
  • Be everywhere: With the widest open fork in the industry, the T6 testers measure up to 11.7mm dia. wires with current up to 200A.
The Fluke 1660 Series of Multifunction Installation Testers put more power in users’ hands by quickly and efficiently testing fixed installations to BS7671 17th Edition Wiring Regulations. They are designed to verify insulation resistance, loop impedance, resistance of the earth connect, resistance to earth, RCD performance in TT and TN systems, phase sequence, and loop/line impedance and RCD tests in IT systems.
The Fluke 1664 FC features Insulation PreTest function that detects if an appliance is connected to the system under test and will stop the test while also providing a visual warning. Insulation PreTest helps avoid accidental and costly damage to peripheral equipment. The Auto Test function, that does 5 required installation tests in one sequence, reduces the number of manual connections, decreases the possibility of making errors, and reduces test time by up to 40% compared to previous Fluke models.
The wireless 1664 FC model is part of Fluke Connect - the industry’s largest system of software and wireless test tools. Measurements from the tester can be wirelessly transmitted to the Fluke Connect app on smartphones or tablets and automatically uploaded to FlukeCloud Storage, eliminating transcription errors.
Technicians can collaborate in real time with other colleagues with ShareLive video calls, increasing productivity in the field. Measurements from the 1664 FC can be combined with measurement data from multiple Fluke Connect test tools to create and share comprehensive reports from the job site via email.
Brand:
Thumbnail image:
Main image(s):
Date of publication:
11/02/2019
Target group:
View the full article
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
