Light fitting suggestion?
Aug 5, 2014
8,683
1,290
Woking
Got a client who has a lighting circuit looped that the lights ............ they want a pendent replaced by a more elegant fitting like a bulkhead / bathroom type light ......... its not a big room and all the fittings I've looked at "assume" that the cable coming to the light will be a single T&E
lucky you. plenty room in there. most these days assume the wiring is a bell wire and make the termianls sized to suit that...
Where you finding terminals that big????
Most would be a struggle to get a CAT5 or Telephone wire in!!!!!!!!!!!!
:shakehead   :slap
When did you last use the connectors that come with a new light fitting??
:popcorn
Be prepared to re- connect the looped lighting in an suitable J/B  above the fitting ,  with a bit of  0.5mm  flex  down to the light  & possibly scrap the supplied connectors .
Theres a whole range of useful  LED   fittings now ,  as the one  Phil shows .
Hum ............ after opening 3 units at a wholesalers today I selected a unit where I can use wago's to deal with all the cables inside the light.......... happy days (fingers crossed)
:shakehead   :slap
:popcorn
or the nasty cheap soft fixing screws!
