aeg 49332i-mn induction cooker
Tony1159
Mar 13, 2019
3
Hi there
I was given a aeg 49332i-mn induction cooker that seems to have a fault on the one side?
When goes through the startup posses you have 5 seconds to set time correctly then you can't alter it after. the right hand panel won't select the grill option as it comes up with f94 or f84 the left hand hob panel seems to work OK
Can anyone help me
Hi there
Thank you for replying
it might be f on The hob but this fault is with the grill which is not induction.
Im wondering as the time clock won't set properly whether this could be the controller  board under the hob on the oven side that is faulty
