DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Social Integrator
Voltimum - Simple color and brightness control for floor-standing luminaires
Social Integrator
Convenient operation
For simple and practical control of floor-standing luminaires and similar applications, OSRAM now offers a new functionality with Touch DIM TW. This means that both: the light color and brightness can be easily controlled via dual push-buttons without an additional control device. This allows the luminaire to be intuitively manually dimmed, switched and adjusted.
Programming via software
All Tunable White drivers from OSRAM are suitable for operating with Touch DIM TW. The LED drivers are configured via the Tuner4TRONIC software in "Tunable White-Touch DIM" operating mode. The brightness and the color are stored by double-clicking the corresponding push-button. The maximum length of the control line is three meters.
Flexible adjustment of the luminaires
Touch DIM TW offers three options for individual setting of the luminaires. Thus, brightness and light color of the direct and indirect luminaires can be adjusted together. Direct and indirect luminaires are then synchronized. This requires two two-color LED modules. However, it is also possible to control the brightness and light color in the direct and indirect parts separately and independently of each other. This requires two TW drivers and two dual push-buttons with two diodes. The third option allows the direct and indirect luminaires to be controlled separately. In this case, only the brightness is adjustable and not the light color, and only two single-color LED modules are needed.
Further information on the wiring can be found on the webiste.
The Tuner4TRONIC software for configuring the Touch DIM TW can be downloaded from www.osram.com/t4t.
Brand:
Topic:
Teaser:
Touch DIM TW for OSRAM Tunable White LED drivers and dual push-buttons
Main image(s):
osram-dam-9865085_futurel_5ms_workstatio
Attachment file:
Description:
Easy color and brightness control for floor-standing luminaires
Date of publication:
25/05/2019
Target group:
View the full article
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
