DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
wheresmyterminal
Sub metering
wheresmyterminal
Haven’t posted for quite some time, it’s come a long way since I was last here. Hoping that someone can shed some light on this for me please. Sorry quite a long one.
My customer has 9 light industrial units. Each unit has its own MID approved single phase sub meter. There is a 3 phase land lord DB that feeds some flood lights and not much else which is not sub metered. To find out what the landlord usage is, he has been reading each sub meters total KWh and adding them all up then deducting this from the main LEB 3 phase meter reading. The KWh result is far more than expected for what is being used from the landlord DB. He’s worried that he’s not charging his tenants enough for electricity and that the single phase meters are not reading correctly. I have checked them and they are installed and set up correctly. My gut feeling is that this is the wrong way to go about it but I’m not sure of the maths. Hope this makes some sense.
Share this post
Link to post
Andy™
simple... add another meter for landlords stuff. total of all meters should be that of the suppliers meter
Share this post
Link to post
ProDave
The single phase meters will be recording KWh.  The 3 phase main meter could well be recording KVAh.  If so with a poor power factor the 3 phase meter will read more than the sum of the single phase meters.
Share this post
Link to post
Geoff1946
Have you looked what the floodlighting load is, and the hours it is on?  Floodlights can be surprisingly hungry.
Share this post
Link to post
kerching
I,posted exactly same thing yesterday and my post has been eaten....not for the first time either!
bit weird
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
