Jimbo8
Voltage on earth ar cu when earth disconnected from earth bar and mcb on
Jimbo8
Hi everyone I'm after some advice I've just noticed that my earth had voltage on when I disconnected from earth bar in cu when mcb was on could any one shed a bit of light on this thanks it is on ring mains and light ccts
Share this post
Link to post
binky
what sort of voltage?
Share this post
Link to post
Jimbo8
Any thing between  118v and 33v
Share this post
Link to post
Jimbo8
33v to 118v
Share this post
Link to post
Rob.
Firstly, it is extremely dangerous to be disconnecting a circuits CPC with it still energized.
Are you measuring with a digital multi meter by any chance?
Share this post
Link to post
Geoff1946
Probably just capacitive coupling from the live conductor.  Why? Are you experiencing RCD trips or something?
Share this post
Link to post
Jimbo8
Hi pal I do realise it not the thing to do I am aware of the dangers but I was alone in the house and I was just seeing if anyone else had come around this thank you
No rcd trips.
Share this post
Link to post
Rob.
As said, most probably capacitive coupling.
Even more likely if you're using a digital meter.
Was there a reason you were doing this? Sheer curiosity or, finding a fault?
Share this post
Link to post
Jimbo8
Yes pal fluke tester also megger multimeter and metrel multimeter all it was I had put the earth in wrong terminal so was moving it over when I noticed a little spark on earth when they was disconnected from each other ie was a ring main but when there together it's no longer there just never come across this before has I've never disconnected earths while a cct has been energised  before
Share this post
Link to post
Rob.
If you got an actual spark, this is suggesting a more sinister fault.
A floating capacitive voltage, shouldn't have enough energy to produce a visible spark.
All other circuit testing ok?
TNCS earthing by any chance?
Share this post
Link to post
Murdoch
Voltages such as you describe are more likely to be "phantom" and are only "there" because the CPC isn't connected to the earth bar. As for the "spark" - may suggest earth leakage.
Best get a spark with an earth clamp meter to investigate, to put your mind at ease.
PS. As others have said its not a wise idea to disconnect the CPC when the circuit is live.
Share this post
Link to post
Jimbo8
I am a electrician a clamp meter would only tell me the loading
I believe it is a tncs rob but u do not get a shock off the voltage that's being produced by the earth
Share this post
Link to post
Jimbo8
Hi Murdoch just in twenty plus years of doing this and have never seen it before I wonder how many sparks have never noticed this with the earths I understand what ur both saying and not to disconnect earths while mcb is on but how would we ever know this is happening  if I never did do it
Share this post
Link to post
Sharpend
You might want to invest in one of these?
https://www.google.co.uk/search?
you can get as said induced/capacitive  voltage however these don’t usually produce a spark? I’d test the earth leakage then the  circuit fully individually as a start.
Share this post
Link to post
Risteard
I think you need retraining about safe working practices.
An incredibly dangerous and stupid thing to have done.
Share this post
Link to post
Jimbo8
Hi there I tested circuit fully insallation  resistance  999 and continuity all ok earth loop 0.81 and rcd all ok
Thanks for ur advise mate but just to let you it would only be dangerous if someone else was in the house just to let you know I was alone
Share this post
Link to post
Murdoch
If you read my post again it says earth clamp meter ............... maybe I should have written earth leakage clamp meter.......
If you do fault finding, they are an expensive but extremely useful item to have
Share this post
Link to post
Risteard
It's dangerous regardless. You put yourself in harm's way by doing it.
Share this post
Link to post
Jimbo8
Have u ever checked the earths dont have voltage on pal guess not so maybe ur leaving people at harm
Cheers murdoch I'm rewiring house now just never seen this before but like we all know we never disconnect earths when its powered up just a one off and couldn't believe what I was seeing really appreciate  you taking time to chat with me thankyou
Share this post
Link to post
Risteard
How exactly is disconnecting them from the Earth bar a good test for anything? And voltage is a potential difference so can only ever be between more than one point.
Share this post
Link to post
Jimbo8
It's not a test I'm asking you a question never mind why not move onto someone else if you cant answer the question all the best thanks
Share this post
Link to post
Sharpend
Let’s stop right there shall we? jimbo you have asked a question that has been answered, it has also been suggested that you’re actions are dangerous, you for some unknown reason now want to turn the good advice into something bad as if you’ve been insulted or attacked?
We all have to learn and if it’s something you don’t understand that’s fine but to insult those that are trying to educate you then that’s not right.
If there is something else about this that you don’t understand then please ask, otherwise try to understand the advice you’ve been given.
Getting defensive serves no purpose other than to prevent people gaining assistance when needed.
Share this post
Link to post
kerching
I would have thought an Electrician would know what an Earth Clamp meter is...maybe it's just me
Share this post
Link to post
Doc Hudson
Some appliances can have natural earth leakage, on occasions relatively high protective conductor currents, (hence section 7.5 of On-Site-Guide). Some appliances can produce earth currents due to faults or deterioration over time. Or an accessory wired incorrectly between live and earth can all produce earth currents / voltages that would not trip and RCD under normal conditions. Unless a full evaluation of exactly what is still connected to a circuit has been made, it is risky attempting to disconnect any conductors of a live circuit. Hence the Legislation against live working. Don't forget 30ma @ 230 is just under 7watts. so a 5watt LED lamp wired between Live & Earth may not trip an RCD, but would put a significant voltage onto the CPC!
on a very simplistic level consider one of these DIY type socket testers https://www.toolstation.com/socket-tester/p82826?searchstr=socket tester  If you disconnect the CPC on a live circuit with one of these still plugged in, depending upon the make of tester it is not uncommon to measure 100+ Volts ac between a disconnected earth and real earth.
Share this post
Link to post
Jimbo8
Thankyou doc really appreciate  advise pal
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
