DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Vincentj
Nexus grid fuse module wiring
Question
Vincentj
I am revamping kitchen and installing a Nexus Grid plate with fuse unit for cooker hood. I have taken a supply from back of socket to the module and on to outlet for hood but fuse only has 2 terminals both marked L. So I have L N and E going to hood and L N and E from supply with fuse in between. What goes into the the 2 terminals both marked L.
Share this post
Link to post
2 answers to this question
  • 0
Evans Electric
L in  &  L out  go to those terminals  .    I presume its just a fuse unit  ...NOT a    switched spur , in which case you need some connectors or Wagos .
Preferably I'd dump the  thing & get a switched spur .
Share this post
Link to post
  • 0
Blue Duck
The L
Should also have a DP switch and that will take care of the N and wagos or similar for the E
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
