DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
choperooni
Hi, my Dimplex XL from 1990s keeps triggering the thermal cutout button. Is it best to check the elements or should I be starting somewhere else? thanks
Share this post
Link to post
Andy™
id be looking at the cloths put on the top to dry
Share this post
Link to post
Geoff1946
Assuming it hasn't been abused by drying anything or otherwise obstructing it's airflow, then the input thermostat probably needs to be replaced. Otherwise the over temp device has become too sensitive.  Can't be the elements or it wouldn't get hot in the first place.
Share this post
Link to post
ProDave
There are several different versions but best replace both the charge thermostat and the overheat thermostat. The usual reason for an occasional trip is the tenant can't read the bit that says "DO NOT COVER" and puts wet washing over it to dry.  If it keeps on tripping the charge thermostat is probably stuck (unless you are putting washing on it every night)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
