Recommendations for expandable fire stopping foam
DaveS79
Mar 20, 2017
238
18
London
Morning chaps
Any recommendations for the above. Need sealant that can be applied around cables passing through holes. One that either comes with plenty of nozzles or can be reused without sealant becoming useless. Thanks
Buy a professional foam gun and gun grade intumescent foam don't forget the foam cleaner to keep the gun clean
https://www.toolstation.com/p45-foam-gun/p84715
https://www.toolstation.com/b1-fire-rated-expanding-foam/p24885
https://www.toolstation.com/pu-foam-cleaner/p30658
The professional gun gives better control of the foam and the can can be left on the gun until the full can has been used
If you are only filling small holes then an intumescent sealant would probably better
https://www.toolstation.com/fire-mate-intumescent-acrylic-sealant-310ml/p58145
Thanks UNG will be buying
Your OP was asking about expanding foam if you are now looking at alternative fire stopping products then have a look at  https://envirograf.com/    they have a wide range of products to suit most if not all situations
just had a look at their site and if the photo demonstrating its use is anyhting to go by, id give it a C2...
25-Intumescent_protection_cable_sleeve1-600x450.jpg.fae984ce70cae21f230a32d4c9463c3c.jpg
