Aaaaaaaaaaaaaahhhhhhhhhhhhhh
Looks like a common problem when adding to exsisting set up
These came with BT Vision and work well. However, I'm glad I read the messages here because I had been planning to extend my network to a 'dead' room that wifi doesn't manage to reach but if, as people say, it doesn't work then it's a lot of money down the drain.
That was a quote from a review on the link you supplied.
Can't speak for these but do use these
http://www.maplin.co.uk/Module.aspx?ModuleNo=48539&C=SO&U=strat15
dead simple to setup as the handshaking is internal to the devices each end
can you expand on how you have tried to set them up, as you are inside the Firewall I would not expect that to be an issue
For the Devolo one plugs in next to the ADSL router and via eithernet cable in to one of the free ports, there is software but not really needed with only a pair on the mains
Just an update, had 2 pairs that were paired together, after a lot of effort I managed to "unpair" all of them and now none of them works. definitely a pants product.
