Hi All,
Split load board..
Well here i was at about midnight, when suddenly half the house electrics trip off..
All MCB's on, [as they would be] but both RCCBS also on too... Hmmm
Try the test buttons.. one works, the other does not.. Hmm some more..
If one RCCB has a feed, then for obvious reasons they both do.. [as the inputs are linked]
Ok, so i soon discover that the one RCCB has a feed, but no output..
Mess about with the button a bit and the output comes back on, sometimes! [and goes off too without a sound or the thing "tripping"]
Ok, so i found a possible earth fault [immersion heater] so this explains the original trip and fault cleared.
More messing reveals that the RCCB trips if it sees an earth fault ok, BUT, resetting the thing does not always work [as in an output from the thing] AND sometimes, despite the thing obviously has a live feed, the test button does not work..
Is this a usual type of thing to see??
john..
Split load board..
john..
