Hi all,
Bought a 13amp plug and play hot tub but want to connect it to my new 32amp RCBO circuit. Got an electrician to run a 6mm 3core SWA cable from it and install an IP rated rotary isolator outside. Given this setup, am I ok to simply wire hot tub with this 6mm cable via a 32amp junction box? I don't want to use the default plug play as want to have jets and heating on at the same time... thanks
