DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
ProMbrooke
Disconnection time 120 volts Uo vs 150 volts Uo
Question
ProMbrooke
Is there any real danger in using a 0.8 seconds as disconnection time for 150 volts line to ground? Or would a sweet spot at 0.7 seconds work? Call me cheap but I don't want to use 0.4 seconds unless I really have to.
Share this post
Link to post
  • 0
Andy™
well table 41.1 requires 0.4 for TN or 0.2 for TT (both AC), so if you want to deviate then you would have to justify that and mark it int he deviations box on your EIC/MWC
Share this post
Link to post
  • 0
Tony S
@ProMbrooke is American, test certificates don't exist.
Share this post
Link to post
  • 0
Andy™
neither does any form of testing
Share this post
Link to post
  • 0
kerching
Switch on
listen
nothing?
jog on
bang?
get someone in
jog on
Share this post
Link to post
  • 0
ProMbrooke
But is there really any danger Andy? I don't see a huge increase in danger between 120 and 150 volts line to ground.
3 hours ago, kerching said:
Switch on
listen
nothing?
jog on
bang?
get someone in
jog on
Lets stick to electrical theory here please :)
Share this post
Link to post
  • 0
kerching
Oh I think you would be unpleasantly surprised at the number of people who subscribe to the aforementioned testing procedure
Share this post
Link to post
  • 0
ProMbrooke
Perhaps. But I more interested in the theory.
Share this post
Link to post
  • 0
binky
OK, in the UK on building sites we use a lot of 110V tools, which gives an RMS value of 50V ish. 50v is regarded as a 'safe' touch voltage, under fault conditions. Clearly the higher the voltage the more risk people are at, but how much difference say an extra 10V adds I don't know.
Share this post
Link to post
  • 0
ProMbrooke
True, but remember that in place like the Republic of the Philippines, Saudi Arabia and South America power is distributed line to line. So its 127 to 138 volts line to ground.
Share this post
Link to post
  • 0
binky
then you need to work with regs pertenent to the country concerned. I'm only familiar with UK regs.
Share this post
Link to post
  • 0
ProMbrooke
UK regs are based off of IEC-60364. Same disconnection time is in the IEC. My question is- does a 0.8 second disconnect time really pose any hazard at 150 volts to ground? If so would a 0.65 second timing be ok? 0.4 seems like extra material.
Share this post
Link to post
  • 0
binky
I'm trying to remeber what the disconnection times were before it all went 0.4?  We suppossedly work on 230V which is roughly 115V to ground and certainly hurts!
Share this post
Link to post
  • 0
ProMbrooke
I'd be curious to know. 138 volts is 69 volts to remote earth so I'm not that concerned going over 0.4 seconds.
Share this post
Link to post
  • 0
binky
it doesn't sound like armeggedon to me :D
Share this post
Link to post
  • 0
Andy™
but 110v site supplies are 55v to earth single phase, 63.5v 3 phase. not his 150v to earth
Share this post
Link to post
  • 0
ProMbrooke
Neither to me.
Share this post
Link to post
  • 0
binky
is it 150V or 75V ? 150V will kill.
Share this post
Link to post
  • 0
Andy™
150v is the voltag the OP is on about. not sure where it comes from
Share this post
Link to post
  • 0
binky
likewise, sounds like foreign places to me
Share this post
Link to post
  • 0
Tony S
120V or 230V to earth is the norm throughout the world. I'm not sure about Outer Mongolia.
Share this post
Link to post
  • 0
ProMbrooke
I'm talking about Uo. On a 138/240 volt Y system Uo is 138 volts. 150 volts at the high end of the 240 volt nominal (260 volts max) supply tolerance.
Edited by ProMbrooke
Share this post
Link to post
  • 0
ProMbrooke
Not necessarily. Philippines, Saudi Arabia, and parts of South America derive 230 volts line to line.
Share this post
Link to post
  • 0
Sidewinder
Firstly with faults. It is the U0 Voltage that we are concerned with.
How are you determining the disconnection time, is this a theoretical exercise, a design or calculation, or is it a measured value which when compare to the breaker impedance is giving these disconnection times?
At the instant of the fault the supply live conductor and the protective conductor act as a voltage divider.
To simplify things, lets allow them to be of equal value for a moment, this means at the instant of fault you are dropping half U0 in the line & half U0 in the protective conductor.
The exact values will vary depending on the exact impedances, but for this model 50:50 will do.
So, with U0=120V this gives 60V at the point of the fault, with U0=150V you have 75V.
From this you can look back at the tables and data in IEC 61140 & IEC 61479 and derive the allowable disconnection times.
These times are related to the physiology of the body, expected heart rate, body impedance etc. For the population based on statistical models.
Share this post
Link to post
  • 0
ProMbrooke
Well put, my exact thinking. :) But what specifically am I looking for in IEC-61140 and IEC-61479?
Share this post
Link to post
  • 0
ProMbrooke
I measured the voltage today, got 122.4 volts line one to earth, 122.5 volts line two to earth, and 244.5 - 244.7 volts line to line.
https://imgur.com/a/UhawBsS
https://imgur.com/a/evv95Pn
https://imgur.com/a/JyyTdsJ
https://imgur.com/a/9sx1lWQ
What would you say?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
