Paul Hayden
Heat Shrink Colours
Paul Hayden
I was questioned recently about certifying an installation.
There was an electrician on the job previous to myself who
used 1.5 sq T+E to wire a light switch. (Brown, Blue, Earth, Feed at the ceiling pendant).
I was told that if I were to heat shrink the neutral cables both ends that the installation would
be fine to certify.  I argue that this is not the case. Would love to know peoples thoughts putting
aside that this is poor workmanship.
Regards,
Paul
Share this post
Link to post
roys
Personally it is no big deal, I always put a bit brown sleaving on the blue to signify the switched live, certainaly good practice.
Many an electrician has made a few quid in the old days and present with the DIYers putting all reds together and all blacks together when doing a fitting replacement, but as I am retired I don’t know what the official line is.
Share this post
Link to post
Paul Hayden
Thanks Roys,
Yes I know technically once it looks ok and heat shrink is on it that it should be fine but It
is a new installation and I am not really comfortable certifying it. Thanks for the response.
Regards,
Paul
Share this post
Link to post
roys
I am sure one of the current 18th qualified sparks will be along just shortly to give you the official line.
i would certainly not be using twin brown cores as the idea is good but just asking for a mistake to be made.
I managed to get current and short together in one sentence 😀 ahh simple things.
Edited by roys
Additional
Share this post
Link to post
Paul Hayden
😂😂 Thanks Roys. Nice Work.
Share this post
Link to post
Doc Hudson
Have a read of Appendix 7, and note3 at the top of page 485.
Share this post
Link to post
Andy™
my thoughts? youre not competent as you dont know the requirments of BS7671 enough to do your job. try section 514
Share this post
Link to post
Murdoch
My thoughts:
why heat shrink? Are we not allowed to use sleeving anymore
why are you considering signing off work you haven’t 100% been responsible for?
Share this post
Link to post
Paul Hayden
Thanks Doc Hudson,
I am following the Irish Reg's so I can't look at those pages.
I will have a look through our reg's at the weekend to see can
I locate some information on it.
Paul
Share this post
Link to post
Murdoch
Just now, Paul Hayden said:
Thanks Doc Hudson,
Paul
Maybe update your location to Eire ....
Share this post
Link to post
Paul Hayden
Thanks Murdoch,
Will do. Still getting to grips with this forum.
Looks very helpful.
Thanks again
P
Share this post
Link to post
kerching
Unless I'm reading this wrong
A) you won't be heat shrinking the NEUTRALS , you will be heatshrinking the BLUE switch wire
B) no,idea why it's heatshrink.   Unless it's an Irish Reg.    I just use a bit of brown sleeving
Share this post
Link to post
NozSpark
IIRC some of my wife's family have said that they have to use twin Brown as switch wires
Share this post
Link to post
kerching
I once had an apprentice first fix the lighting in twin red on a very large house
that was fun
Share this post
Link to post
Paul Hayden
HI NozSpark,
Yes, thats definitely what should have been used.
Given the nature of the error and other reservations
I have decided to walk away from then job. Its not
worth exposing myself.
Thanks for everyones comments.
I will try to be an active member.
P
Share this post
Link to post
roys
. Its not worth exposing myself.
Operation Yew Tree😀😀
Share this post
Link to post
Risteard
It is prohibited to use a core of an incorrect colour and heatshrink it under ET101.
It MUST be replaced with twin brown I.S. 201-4 (new type T&E with full-sized insulated cpc) cable.
But the QC (Qualified Certifier) should know this.
Edited by Risteard
Share this post
Link to post
kerching
That's interesting
I never knew or heard of that....makes sense though all cores the same size and insulated.    Apparently in USA they don't even sleeve the earth AND I believe you can only have 1 core in a screw terminal so they are all fastened with a Screwit and a pigtail brought out
Share this post
Link to post
Sharpend
1 hour ago, kerching said:
That's interesting
Is this to aid conductivity in the ‘flash bang’ test?
Share this post
Link to post
Risteard
On 24/01/2020 at 15:00, Paul Hayden said:
Thanks Roys,
Regards,
Paul
Out of interest, why are you certifying someone else's installation work?
The only time that this is permissible is after having filed a Change of Contractor request, and then only after having received written authority from RECI to proceed. In every other situation it is prohibited and will result in disciplinary action (including expulsion) from RECI. The only other exception to this is the "Test Only" cert where an installation has been de-energised for over six months to get the DSO (ESB) reconnection.
Share this post
Link to post
roys
Risteard, just asking out of interest and following on from what you have said, does that mean you can’t have the situation in say a bigger company where you have one man in the company just going round doing the testing of the various site teams within the company?
Share this post
Link to post
Risteard
The company must have at least one Qualified Certifier (QC). Legally only this person can carry out the inspection and testing (and certification). So the others in the company could carry out the work but it must not be energised without a/the QC having verified it.
For a large company they would generally have numerous QCs.
A QC Number is valid for five years, after which the Testing and Verification course must be resat. Without resitting the course a new QC Number cannot be issued and certificates cannot be issued.
So the company will have a RECI Registration Number, and each and every QC will have a QC Number, e.g. QC1234/012020 which would mean that the QC Number is 1234 and it expires in January 2020.
Share this post
Link to post
roys
Cheers Risteard.
Share this post
Link to post
Sharpend
It’s a far better system than we have here that’s for sure. Does it get abused in any way?
Share this post
Link to post
Risteard
The potential for abuse largely arises out of Registered Electrical Contractors illegally selling certs to non-RECs.
Whilst this does happen I would like to think that it's not commonplace (at least not anymore).
The other problem is if a REC certifies someone else's job without going through the required Change of Contractor procedure. Again, I would like to think that this doesn't happen often as it is grossly unfair to those of us who actually comply with the RECI Rules of Registration and puts us at a competitive disadvantage.
Edited by Risteard
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
