DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Jax
Repairing blossom wall light
Question
Jax
Hi there.
I am refurbishing a wall light. It's like a tree branch with blossoms, each blossom represented by a little bulb.
https://picclick.co.uk/Habitat-Tse-Tse-Cherry-Blossom-LED-Light-202302027481.html
There are three types of bulb:
Round white
Long pink
Teeny clear
Various clusters and branches weren't working but I have got most of it going again by a painstaking process of bulb testing and swapping. There is no rhyme or reason to how these bulbs affect each other! Funfunfun.
I have got some branches going by short-circuiting blown white bulbs by wrapping the bases with a sliver of tinfoil. Is this safe or silly? I have found a few bulbs that look right on ebay so hopefully it's only temporary. None of the foil is exposed.
I am short by 7 or 8 of the teeny clear bulbs, though. I have managed to get their branches going by stuffing tinfoil into the vacant bulb holders. Can someone tell me the best way of permanently making the current travel across these holders? Would it be enough to put a blob of some electrical / heat resistant adhesive on top of the foil?
(Ideally I would replace with new bulbs but can't find anything like them - their bases are smaller than the other two types.)
TIA
Share this post
Link to post
9 answers to this question
  • 0
Sharpend
How about we stop with the foil tricks and ask if we know where to get the lamps you are looking for?
they are not lamps but individual light emitting diodes (led)  by the look of the picture. What have you found?
Share this post
Link to post
  • 0
Jax
Sorry, the picture is wrongly titled. Pretty certain they are lamps. Here is a pic of some similar on ebay https://www.ebay.com/itm/15x-Replacement-0-23w-BULBS-for-Habitat-Natale-Christmas-Tree-etc-RED-PINK/163981013981?hash=item262e07b3dd:g:xRcAAOSwKAFd7lW7
(When the forum allows me to upload pics after 10 posts I will be able to show you better pics of what I have)
But sadly I cannot find anything that looks like the tiny clear ones, which have a smaller fitting.
I was doing foil tricks mainly to see if it was repairable - I didn't start with the intention of using it like that, honest Guv!
Do you know, pray, where else I might be able to look for tiny bulbs to try and get a match?
Share this post
Link to post
  • 0
Sharpend
Have you looked for individual led lamps?
https://www.google.co.uk/search?
Share this post
Link to post
  • 0
Jax
Yes. Haven't seen anything that looks like it will fit.
Share this post
Link to post
  • 0
Sharpend
Then I guess we’ll have to wait for your 10 posts! If you use a third party pic app then you can add a link to that now if you like.
Share this post
Link to post
  • 0
Jax
Share this post
Link to post
  • 0
Geoff1946
Some guesses:    From the picture It looks as though it runs off a low voltage adaptor?  If so at least you won't be dealing with hazardous voltages.  (Check!)
I suspect that there will be several series wired chains each made up of several leds . That would explain the apparently random inter-dependencies.  By shorting out some lamps you will be increasing the voltage on the others in that chain and are likely to shorten their life.
The odd things are firstly that the leds are removeable, a feature I've never seen, - most leds are non-replaceable, and secondly that they have failed, as they are usually very reliable. Are you sure its not just connection problems?
Share this post
Link to post
  • 0
Jax
Thanks Geoff! They aren't LEDs, they are little filament bulbs. My bad - the title on the picture I chose is wrong. I will upload some pics of the actual thing today one way or another. It runs off a 24v adaptor.
Share this post
Link to post
  • 0
Geoff1946
OK. I assume there are no markings on the dead lamps?
So first work out what voltage they are. Check how many go out when one is removed and divide 24 by the number.  e.g. if you take out one and three others go out there must be a chain of four in series. Hence each is 6 volt.
Next issue is to identify the base type. The smallest common type I've met is called LES -  Lilliput Edison screw. These are about 5mm diameter and were popular on Christmas lights about 20 or 30 years ago when they were largely replaced by push in "wedge" types. Googling miniature lamps may help the identification.
Just spotted your posting of similar items. Those are what I call push in wedge types. The bad news is that sizes vary slightly. The good news is that you can pull the lamp our of the wedge bit and insert a new one, so don't lose the plastic wedge bit.
Edited by Geoff1946
Afterthought
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
