Copper Beech
- Feb 28, 2020
- 7
- 0
I am building a temperature control box using PID’s and Solid State Relays (SSR). I have a problem with adding a neon indicator across the SSR output to indicate when mains is switched the control signal input. Without the neon the SSR has 240v on the input and 0v on the output ie. no control signal input so no output. When I connect the neon, it lights even though the SSR output should be 0v. However there is 100v at the output?? Help anyone. Photo below. Many thanks in anticipation.
