DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
gibsonkyle
My Neff oven has stopped heating and noticed grill not working.  Not sure if grill went at the same time. The fan and light works. If I replace oven heating element will this get oven part going again
Share this post
Link to post
Geoff1946
First check you haven't accidentally confused the timer.  That accounts for a LOT of "failed" ovens.
Beyond that it's impossible to say, but if two things failed simultaneously its more likely to be a wiring or control fault than two elements.
Share this post
Link to post
gibsonkyle
I have set the correct time on the clock so I know it's not it.
Share this post
Link to post
ProDave
Fan oven element is separate to the grill element.
It could be an over heat trip?  Or if it's old style with a big mode selector switch they can fail.
Share this post
Link to post
gibsonkyle
Its about 20 year old. Where is mode selector switch located?
Share this post
Link to post
ProDave
It's the big switch you turn round to select grill, normal oven, fan oven etc.  It's a big thing and has 10 or more wires connected to it. they cost about £60 so at 20 years old I would just get a new oven.
Share this post
Link to post
Geoff1946
Suggestion:  Take off the back panel of the cooker, (with power isolated, obviously), and examine the connections where the elements are wired.
It's not uncommon for the push on connectors to loose their grip and get hot to the point of burning out.
Any deeper investigation requires test equipment which you probably don't have.
Share this post
Link to post
gibsonkyle
Ok. I'll take another look at it. Thanks for all the help
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
