Hi guys, hoping you can help. I have one 7.2kW EV car charger wired up with the relevant RCD, and an isolator switch. We're having a second (3.6kW) EV charger in the same location (because it's a different plug to the car) I'm aware that the supply with only support one charger at a time, I need a switch that I imagine something rather like an isolator, (I'm not sure if it's in place of the isolator) but it has an "A", "B", and 'OFF', is that possible and straightforward for an electrician to fit ?
any help (or links) much appreciated
thanks
Paul
thanks
Paul
