OK so whilst investigating some failed communal lighting I opened up a lampost - found my problem, cable wasn't connected. However, I also found a few surprises:-
1/ cable used was split concentric not SWA.
2/ neutral and earths jammed in same connection, so effectivley creating a PME arrangement.
So question is, is this a safe way of wiring lamposts set into the ground, or has someone not understood what split con is? NB all bollard and lamposts lights have been wired in the same way on this small private housing estate.
