Socket plug installation
Sambna
Apr 13, 2020
2
Morning everyone,  I work as senior engineer.  My work dont evolve alot of electrical work . So iam only has little experience of the buildings wiring etc ..
As you can see from the photo attached is a single light switch in my outdoor shed .  I would like to install a double plug socket underneath it . I will appreciate it if someone can help me with the wiring . I guess I will need an fcu ?
Thank you.
Sam
If the only electrics in the shed is the light, it’s probably a good idea to determine where it’s fed from as it could be off the lighting circuit. If this is the case adding a 13A socket wouldn’t be a sensible idea.
What photo?.....jus saying
I thought I added url for the single switch photo.
But for some reason I cant do it 🤷‍♂️
I will have a look and let you know cheers 👍
