I'm wiring LED strips above and below a kitchen cabinet. I can successfully power the first strip above the cabinet
. However cannot power the second strip
. I've checked the correct colours to the rgbw+ connectors etc and they are aligned correctly.
I can only assume the connections aren't good inside the adapter clips, however i've redone them a number of times as best I can and still no difference.
Am I missing something obvious?
Cheers.
Cheers.
