boltonsparky
Revision Question
boltonsparky
Thought I'd ask on here.
It's difficult (for me at least) to determine what they're actually asking.
If they're asking max volt drop for a distribution circuit it would be 5%, 11.5V so answer a) 11.5V
But are they asking what the acceptable volt drop would be if you included the 5V they mention, so answer c) 6.5V
In my mind if you tested for volt drop at the DB, the final circuit (after your test point) with the volt drop of 5V would already be included in the test result as it is coming off the DB so the answer would be 11.5V.
I've asked elsewhere and the general consensus is c) 6.5V but I'm not convinced and it has me baffled.
I think they're tying to throw you off the scent with the 5v thing and are just asking what the max permitted volt drop for the circuit would be.
IMG_1337
Edited by boltonsparky
Share this post
Link to post
Murdoch
After a long hot tiring day I would say 6.5 volts
Share this post
Link to post
apprentice87
Me too.. Very badly worded question though...
Do not forget they are taliing about verification of an EXISTING installation. If as they claim [presumably after some calculation] that the volt drop of the "worst" final circuit is 5 volts, then yes, the most you could drop up to the origin of that final circuit would be the balance of the permitted 11.5V, so the answer would be 6.5V
john..
Share this post
Link to post
boltonsparky
Cheers fellas.
I did the test today and passed, officially have my 2391 now although the certificate won't turn up for a while yet.
I'm ready for a  Guinnesstonight.
Share this post
Link to post
Murdoch
1 hour ago, boltonsparky said:
Cheers fellas.
Good man.
The question is worded like a GCSE maths paper - easy to miss the "double" question in the text
Share this post
Link to post
apprentice87
So what was the right answer then??
john..
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
