700 Watts from solar panel and battery
Status
Not open for further replies.
Malcolm.f
Aug 7, 2020
2
Hello all,  could I ask for some advice.
I would like to run a 700 watt Clarkes electric pump at my allotment to water the plot from a ground water well.  (I currently run this at home off the mains and it works fine).
So my thoughts are
1. A solar panel to charge a battery
2. A charge controller
3. A 1000 watt inverter
4.  A car battery.
My question is:  How long would a 700 watt pump run off a fully charged car battery?  Would I be right in thinking that a 700 watt motor would draw 3 amps?
If the above setup works, what power battery would I need and approximately  how long would it take to charge up after using it for an hour?
BTW - I typically water the allotment every 3 days.
Malcolm
A typical 60Ah car battery will store a total of 720 watt hours, so in theory would run your pump for one hour. the reality given you can never fully discharge a battery and the inverter losses would be more likely half an hour.
You would probably do better to try and find a 12V pump to eliminate the inverter.
Thanks ProDave,  I'm not sure if I can source a 12v pump but I'll take a look around.
you need a leisure battery not a car battery - wrong battery tech.  How bid a battery depends on how long you use the pump for.
Status
