Keithxj8
Veritas r8 installed all ok but when I select part set the panel does not beep on exit or re entry just indicates the zones ommited. The system arms and works fine but I need the panel to make a sound as my wife is hard of hearing.
Share this post
Link to post
Andy™
part set is set to silent
Share this post
Link to post
Keithxj8
How do you remove this setting please.i have read instructions till its double Dutch.
Share this post
Link to post
Andy™
misc selection 01 4 to off. default is off so you must have changed it already...
Share this post
Link to post
Keithxj8
Cheers just checked both 00 and 01 neither will change sound to same as full set so it beeps when setting on part. Maybe it just is like this .
Any help appreciated
Cheers
Share this post
Link to post
Keithxj8
All sorted I have added a 16ohm speaker to the LS connectors in the main control panel which amplifies the sound adequately.
Now when setting on part there is an audible sound until it is armed .
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
