unused economy 7 spurs?
cindybarraclough
Oct 1, 2020
I have just had a new instant heat water system installed. the Electrician wired it into the old immersion heater switch.and capped off the place next to it into which the economy 7 immersion heater was wired. Now the old massive water cylinder has been remover it is now a useful storage space But it needs a light in it. can I use this for a light socket  or wire a poll switch light into this?
The cable could be re purposed to feed for instance a socket by some alterations at the consumer unit(s)
But assuming this is upstairs with a loft space above, it would probably be a lot easier to connect a proper ceiling light and light switch connected to the existing lighting circuit.
I am interested to know how you get on with a 3kW instant water heater. That's going to be a pretty low flow rate and not a patch on what you would have got from a hot water tank.
