kammx4
Hi i have a 105e that has NO flashing errors. Central heating works fine, but when you turn on the hot tap water gets to a temperature then boiler turns off then 20 seconds later starts to heat the water again and so on and so on. Ive changed the diaphragm and its still the same. Any help or ideas would be greatly appreciated.
Share this post
Link to post
Andy™
diverter valve or heat exchanger blocked
Share this post
Link to post
kammx4
I believe there's a way to test either??. That should say BAXI by the way.
Share this post
Link to post
Doc Hudson
Edited that for you. another one of the joys of predictive text.
Share this post
Link to post
kammx4
Many thanks.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
