Wonder whats going on here?
Aug 5, 2014
8,669
1,286
Woking
 I was asked to look at a fused spur this afternoon
Bearing in mind its on a 32A socket circuit, all those cables look a bit small and why the connection between the blue and brown?
I recommended further investigation
Could it be. A supply in switched love and neutral. To the light or fan and a switch wire from the switch on the wall to the fused spur ie a bit like 3 plate wiring a light fitting but at a spur instead 🤔
Is that something to do with heating with a cable off to a room thermostat or similar?  More than just a supply in and fused out.
