Traineeboy 11 Report post Posted February 6 Just wondering if you wanted to move a consumer unit location without a full rewire how would be best to do it ? would it be to use an adaptable box with the correct connectors inside it to connect the cables ? Or is there a better way ? 0 Share this post Link to post Share on other sites
Sharpend 1,120 Report post Posted February 6 Depends on how far from existing, if cables can be moved then move them if not a large adapt box with din rail and din rail connectors is a tidy way of doing it. 0 Share this post Link to post Share on other sites
Murdoch 535 Report post Posted February 6 Just remember that the connections will almost certainly need to be accessible .. why is it being moved? 0 Share this post Link to post Share on other sites
boltonsparky 68 Report post Posted February 6 Second vote for an adaptable box with din rail connections. I think Wago do some din rail mountable push fit connections. 0 Share this post Link to post Share on other sites
Andy™ 2,584 Report post Posted February 6 why is it being moved? if its to put somehting else there then an adaptable box would be just as in the way as the unit its self. depending where cables come from you could pull them back, replace them to the first point, crimp and heatshrink, wago's in wago box or a mixture of all & other methods... 0 Share this post Link to post Share on other sites
Traineeboy 11 Report post Posted February 7 15 hours ago, Murdoch said: Just remember that the connections will almost certainly need to be accessible .. why is it being moved? customers wanted it within reach and too high on wall Thanks again for your input. I’ll look into din rail connectors 0 Share this post Link to post Share on other sites
Murdoch 535 Report post Posted February 7 39 minutes ago, Traineeboy said: customers wanted it within reach and too high on wall a short ladder would be far cheaper 0 Share this post Link to post Share on other sites
monkey5 59 Report post Posted February 7 wago din rail connectors are really good and makes a good neat job 0 Share this post Link to post Share on other sites
Traineeboy 11 Report post Posted February 8 20 hours ago, monkey5 said: wago din rail connectors are really good and makes a good neat job Neat - any links for those connecters ? 21 hours ago, Murdoch said: a short ladder would be far cheaper lol yeah - they want a new board too so might as well move it. 1 Share this post Link to post Share on other sites
boltonsparky 68 Report post Posted February 8 sold at CPC, CEF, RS and probably your local wholesalers. Other brands are available and they're available with screw and push fit connections. 0 Share this post Link to post Share on other sites
binky 1,038 Report post Posted February 12 another little trick is to extend ring mains with 4mm or 6mm, so you have a single cable into your CU in it's new location - less cables, neater job. 0 Share this post Link to post Share on other sites
Murdoch 535 Report post Posted February 12 2 hours ago, binky said: another little trick is to extend ring mains with 4mm or 6mm, so you have a single cable into your CU in it's new location - less cables, neater job. the only downside is that it makes it trickier to fault find later 0 Share this post Link to post Share on other sites
binky 1,038 Report post Posted February 13 18 hours ago, Murdoch said: the only downside is that it makes it trickier to fault find later I tend to split a ring at a socket these days - you generally have to drop a few socket fronts off to fault find anyway. 0 Share this post Link to post Share on other sites
NozSpark 1,043 Report post Posted February 13 On 07/02/2021 at 12:33, monkey5 said: wago din rail connectors are really good and makes a good neat job Looks neat, but the only problem I see with using DIN rail terminals is that the earth ones tend to ground to the DIN rail, so effectively joining all the CPC's together and messing your readings right up... 0 Share this post Link to post Share on other sites
Murdoch 535 Report post Posted February 13 5 hours ago, binky said: I tend to split a ring at a socket these days - you generally have to drop a few socket fronts off to fault find anyway. One I recently was trying to fault find was 6mm brown / blue at the CU and 2.5mm at all the sockets - so I never did find where the join was. The customer knew where the fuseboard used to be but there was certainly no access to any joints 0 Share this post Link to post Share on other sites
