DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
insulation test
mark303
Hi people
can anyone help with a problem insulation testing with a megger 1552
keeps coming up 000 whatever its connected to when the test button is
activated
have I broke it?
Link to comment
try connecting all the leads together .. and test .. try again with all leads seperated .. what do u get ??
i can get this if the leads are not pushed in tight
Link to comment
with both leads connected 000
leads seperated 299
er... your supposed to get 000 with leads touching?
Link to comment
why stil 000 when connected together through a new roll of cable one clip to brown one clip to blue blue and brown together at other end
Link to comment
your testing insulation between conductors. you do not short it together at any point
Link to comment
you want the highest possible resistace. you do not 0 test leads for IR, but shorting them together to get 0 before a test ensures they are correctly connected to tester
Link to comment
if you ir test a short piece of cable say 1mm csa would you get a reading and what should it be assuming the cables good
The Don would expect a high reading, perhaps 299.
The Godfather
Link to comment
If you IR tested a brand new reel of T&E I would expect to get >299mohms on all the readings....
DO NOT CONNECT TOGETHER THE OTHER END
Link to comment
299Mohm
The Boys
Link to comment
My sincerest apologies DonBlushingBlushing
I don't know what came over me:_|, I hope (Pray) that the boys aren't on their way;)
Link to comment
for a new cable, expect a reading higher than your test kit can measure
Link to comment
so the test leads have no resistance
your testing the IR, try one clip on brown one on blue but dont join the other end.
Link to comment
dont forget you also need to test the earth
Link to comment
Think O/P confused insul. with cont. testing.........
Link to comment
KME the forum was discussing your absence only the other day, hope you are well and welcome back!!
Link to comment
Sounds like it to me too. :)
Where have you been hiding Mate?
Great to see you back online.
Best Wishes,
Admin.
PS. I have heard from Mr Sworld, Guys - He will be rejoining us soon. Haven't heard from Steps though.
One big happy family. :D:x
Link to comment
Archived
  • Create New...
