DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Pat testing
mcgaw81
What is the going rate of Pat testing, per item. I have been asked to test a golf club and haven't priced such works before. Is it about
Link to comment
Golf clubs don't need power. The movement comes from the swing of your arm..........
:coat
Link to comment
i normally charge around
Link to comment
As Apache says , how would you test a golf club . Someone is pulling your sporran Mac , there is no flex on a golf club. ;)
I charge
Link to comment
I've just done some at a business premises...
I charge
Link to comment
I have found that if you drop your pricing to match the fly-by-nights you end up in as much serious in trouble as they do.
I do the occasional PAT testing but I try to get out of it as much as I can simply because I can not compete with the unskilled plug and play testers out there.
Incidently I found an industrial unit where every socket outlet had a PAT label on.
Loverly juberly, the con artists they are.
Link to comment
Funny this should come up....
I happen to speak to a guy doing some PAT today - the job he was on was for a client with 20,000 items to be tested - at 60p each!
I was watching him PAT in an office, using a seward tester (most the kit being tested was Class II) - the tester had a thin wire and probe (no clip) for the Class I tests. He wasn't keeping a register, wasn't recording serials or details, wasn't checking fuses, didn't check polarity on leads. Simply plugged the lead to the tester, hit start and job done - sticker applied!
He didn't even have any failed stickers - only pass!
O.
Link to comment
O.
Quality untrained rip off comes to mind.
I would expect there are loads more tested just like this.
It takes me ages when I do it because I have to register, log it, check the plug top and fuse rating, check for wear and tear on cable, test whilst moving cable to see if there is any underlying faults, record the tests on the log book and so on and so on.
Thats why I hate doing them, I have two PAT testers and I keep threatening to throw them out.
Link to comment
This guy averages 200 - 300 items per day (office environment).
With this client/site he claims he's done 400 each day (12 hour days)
**** me - thats motoring! :o
O.
Link to comment
That comes out a 1 min 48 seconds per item, without any breaks....
He's just putting stickers on (no testing) isn't he????
Link to comment
O.
No wonder they are doing it so cheap, whats the point in bothering if thats going on.
Link to comment
I don't think the client are actually bothered about safety, they are doing it to comply with their insurers...and if worst comes to worst, they can show the HSE everything was tested! :(
O.
Link to comment
O.
'it was alright when it was tested 2 months ago' !!!!!!!
due diligence covered Guiness Drink
Link to comment
If you can do more than 12 PAT tests per hour you probably aren't doing it right! Price what you do accordingly!
Link to comment
Just what I was thinking.. 1 every 5 mins.... Inc testing & documentation (my version!)
Link to comment
I tend to manage 8 per hour, and charge my normal rate.
The funniest thing is always when you fail something (I try to repair as I go) - people want everything to pass, that's why the 60p per item boys get the work. "elf'n safety mate" - health & safety my a*se!
Link to comment
the 60p boys would have passed it
Link to comment
yep.....
passed the house and put the stickers through the letter box !!!!!!
Link to comment
Archived
  • Create New...
